Hello everyone.
I have an audio amplifier (which doesn't work) and I'd like to get it working because it's good stuff (
Fender Rumble 150 Bass Amplifier Head)
It just doesn't turn on. From what I can see the power supply (ICEpower 50ASX2) doesn't have any active output... but it's something more complex than the ones I've been trying to repair and learn, this one has more components
If anyone can give me some help.
I found some information available for this power supply:
Esquema do AmplificadorManual da FonteDatasheet da FonteBut I can't find the schematic of the entire circuit\components
I've been doing some measurements and unfortunately the fuses (which are about 3) are all fine, the 2 giant capacitors (primary side) have a voltage of ~150V each
On the secondary side, I don't have any voltage, even on the Enable Pin that should be +5V (according to the manual) has 0V.
There is one component that is an NTC 5.0 and has a resistance of ~5R, which makes me believe that it's fine too.
I don't know however if this is normal:There are 2 components at the bottom, and next to the larger transformer (on the primary side), which on one side have voltage but not on the other, it's a capacitor and a black component (looks like a diode, it says "EB 11"), the voltages in this part are like this:
is supposed to have on one side of the capacitor, and that diode, voltage but not on the other side?
Testing the "diode EB 11" in the normal way (with the multimeter in the diode mode) has 0.445 and in the reverse it has 2.950 (but it could be because it is in the circuit, I haven't tested it outside).
All the elect. capacitors from the board, i measured them (with the multimeter in the capacitor mode) and the values, even being in the circuit (I didn't remove them), seems to be ok, and they seem to be of good brand and quality..
There are 2 large transistors next to the larger transformer (primary side), are they responsible for activating the voltages?
