Author Topic: faulty insulationresistance meter.  (Read 649 times)
Offline kakha4Topic starter
« on: August 12, 2022, 12:44:26 am »
have a faulty IR continuity tester (CABAC model T2732). On the 500 ohm setting(when doing initial testing) the needle deflects to 50 ohm only whereas it is meant to give a full scale deflection to 500 ohm whereas on the 3 ohm setting the needle give s a full scale deflection. any suggestions as to what could be causing this?.
« Last Edit: August 12, 2022, 12:46:25 am by kakha4 »
Online themadhippy
Re: faulty insulationresistance meter.
« Reply #1 on: August 12, 2022, 01:27:31 am »
Does the zero adjust do anything?
« Reply #2 on: August 17, 2022, 01:25:34 am »
its zeroed properly. tested on the 3 ohm scale. its just the 500 ohm setting when testing needle only deflects to 50 ohm range and not past it.confused?????
