Author Topic: Faulty resistance range Velleman DMM  (Read 11513 times)
Offline BlaffetuurTopic starter
« on: June 06, 2016, 02:48:34 pm »
I have been using my Velleman DVM9912 for some years now but recently noticed that my resistance measurements are wrong. These are the things I observed:
-All functions except resistance work (checked against my dad's fluke)
-Without anything connected I measure 4k8 ish
-There is a PTC near the righthand connector on the board and when I hold it to warm it up I see the resistance measurement go up a few hunderd ohms
I don't remember what I've done wrong, one thing that could have happend is that I turned off the meter while measuring current.
Do you guys have any suggestions as to where to look ?
(And what could be the function of that PTC ? Is it a protection device or does it some compensation for the temperature measurement ?)
Here are some more pictures: http://imgur.com/a/YVxzI
« Last Edit: June 06, 2016, 03:30:56 pm by Blaffetuur »
Offline retiredcaps
Re: Faulty resistance range Velleman DMM
« Reply #1 on: June 06, 2016, 02:57:03 pm »
Your Velleman looks like it was made by CEM Instruments.
Using the Fluke, measure the resistance of the PTC.  It should be around 1k ohm.  Please post your reading.
The PTC is for input protection.  See
« Last Edit: June 06, 2016, 02:58:53 pm by retiredcaps »
Offline retiredcaps
« Reply #2 on: June 06, 2016, 03:00:32 pm »
If the probes are shorted, do you get 0.0 ohms on the meter?
« Reply #3 on: June 06, 2016, 03:04:35 pm »
The PTC measures 890 ohm
And with probes shorted I get 0 ohms
Offline retiredcaps
« Reply #4 on: June 06, 2016, 03:06:28 pm »
PTC reading seems okay.
Can you post clear focused pictures of the entire pcb, both sides please?
« Reply #5 on: June 06, 2016, 03:28:22 pm »
Here are some more photos
Couldn't find my sony camera so my phone had to do  :P
Offline retiredcaps
« Reply #6 on: June 06, 2016, 03:35:13 pm »
Pretty good for the phone camera.
Your range switch definitely needs a good clean.  See
http://mrmodemhead.com/blog/fluke-83-iii-rotary-switch/
Offline retiredcaps
« Reply #7 on: June 06, 2016, 03:38:01 pm »
Hmm, did that flying capacitor across the main COB come from the factory?  Same for the yellow bodge wire?
CNR1 is a MOV.  Can you use the Fluke to measure its resistance?  It should measure 0L, open circuit.
edit: pictures saved for future viewers.
« Last Edit: June 06, 2016, 03:58:36 pm by retiredcaps »
Offline retiredcaps
« Reply #8 on: June 06, 2016, 03:44:39 pm »
It looks like version 3 of this board removes the flying capacitor.  Picture in the
https://www.eevblog.com/forum/testgear/help-required-who-is-the-oem-of-this-multimeter/msg265980/#msg265980
« Reply #9 on: June 06, 2016, 03:47:31 pm »
This is the first time I open her up so yeah  :-DMM
I measure 1k across the MOV  :o
Offline retiredcaps
« Reply #10 on: June 06, 2016, 03:52:41 pm »
1) Desolder the MOV and measure it out of circuit.
2) Measure the solder points on the pcb after the MOV as been removed.
3) With MOV removed, retest the ohms measurements.
Report all of the above.
Offline retiredcaps
« Reply #11 on: June 06, 2016, 03:56:20 pm »
« Last Edit: June 06, 2016, 03:59:17 pm by retiredcaps »
Offline retiredcaps
« Reply #12 on: June 06, 2016, 04:03:55 pm »
I can't quite read the part number of CNR1?  Can you post it?
« Reply #13 on: June 06, 2016, 04:10:38 pm »
Doesn't make a difference, desolderd MOV measures OL, pcb measures 1k and without the MOV the meter still reads 4k8 ...
« Reply #14 on: June 06, 2016, 04:11:43 pm »
VDR
07D270K
Offline retiredcaps
« Reply #15 on: June 06, 2016, 04:14:03 pm »
Okay, you can put the MOV back in.  I will have a look at the MOV datasheet.
Have you cleaned the range switch yet?
« Reply #16 on: June 06, 2016, 04:17:44 pm »
Yes, cleaned it up with some kontakt spray but didn't solve it
Offline retiredcaps
« Reply #17 on: June 06, 2016, 04:31:32 pm »
I use 91% IPA and scrub with a toothbrush.
Offline retiredcaps
« Reply #18 on: June 06, 2016, 04:36:07 pm »
VDR
07D270K
Hmm, this MOV is only 18V.
http://pdf1.alldatasheet.com/datasheet-pdf/view/553484/BOURNS/MOV-07D270K.html
It must be doing something else than what I thought.  Normally the MOVs are located close to the input jacks, but with the CEM spaghetti layout, I thought it was reasonable to assume this MOV was part of the input protection.
As I mentioned in the Fluke 89IV thread, I need a break.  I'm participating in 3 repair multimeter threads at the same time and it is all starting to blur together.  I'm also gone for a few hours later in the afternoon.
The following users thanked this post: Blaffetuur
« Reply #19 on: June 06, 2016, 05:03:03 pm »
VDR
07D270K
I appreciate your help alot ! I'm the asking party so you really don't need to justify your effort  :-+
Offline retiredcaps
« Reply #20 on: June 06, 2016, 07:04:40 pm »
Hmm, it could be nothing, but R7 and R8 in your picture look like they are touching? Circled in red.
If they are touching, separate them slightly.  I don't think this will solve the ohms problem, however.
Offline retiredcaps
« Reply #21 on: June 06, 2016, 07:06:18 pm »
Can you replicate the two readings in this thread
https://www.eevblog.com/forum/repair/fluke-89-iv-powers-up-measures-nothing/msg956417/#msg956417
I only need pictures #2 (1354) and #3 (1355) replicated.  Your Dad's Fluke = Fluke 77 III and your Velleman = 187.
Offline retiredcaps
« Reply #22 on: June 06, 2016, 07:19:57 pm »
I forgot to say please, do the tests above with auto ranging first and then do the same going through the manual range.  I want to see what your meter output/sources through the various ranges.
Offline retiredcaps
« Reply #23 on: June 06, 2016, 07:26:46 pm »
Can we also get a picture of the pcb with the LCD removed?  It looks like you need to remove the 4 screws to release the LCD.  With all the bodges, let's see if there is anything interesting there?
Offline retiredcaps
« Reply #24 on: June 06, 2016, 07:51:45 pm »
Sorry for the multiple posts, but more ideas coming to me now after a little break.
Does your meter show 0L or open circuit with probes removed in following scenarios?
1) manual 400 ohm range
2) manual 4k ohm range
3) manual 40k ohm range
4) manual 400k ohm range
5) manual 4M ohm range
6) manual 40M ohm range
