Hi there,
Here is my experience of repairing a small guitar amp. I think it's finally good but I still have a few questions about the circuit.
I got the amp in last December for 10 euros, sold as non working. The transformer was dead, the primary was an open circuit. Somebody apparently already had a go at trying to repair the amp since many wires were cut (first picture). I tried powering the device by injecting DC directly into the circuit with a lab power supply and it worked.
So I thought that ordering a new -/+15 VAC transformer would be enough. What I didn't know is that a transformer may deliver a significantly bigger voltage when it's not fully loaded. Moreover the transformer I bought had a higher power rating, and therefore a higher unloaded voltage. I think this voltage difference was just enough to go above the absolute maximum supply rating of the main amplifying IC, a TDA2050 which literally vaporized. At the time I was totally ignorant about transformers, so I though that it was Farnell's fault delivering me a 18 VAC transformer instead of a 15 VAC one
. (You can learn more about my stupidity in a topic I opened here at the time
https://www.eevblog.com/forum/chat/hopeless-problem-with-farnell-need-advise/)
When I finally understood what happened, I ordered a replacement TDA2050. In order not to bust the new one, I placed two 1N4007 diodes in series with each power rail so that around 1.4 Volts would be shaved on each side. With that dirty hack, the amp finally worked ! Now I think that the design of the amp is stupid: according to the schematic, the TDA2050 is fed with unregulated, just rectified -/+23 Volts when the maximum permitted supply is 25 Volts. Even with the original transformer a 10% increase in mains voltage could have fried the IC. The second picture shows the amp with the new transformer. Since it is bigger than the old one, I mounted it on the bottom of the case.
When I started testing the amp, I found a new problem, the reverb setting had absolutely zero effect on the sound. To troubleshoot this new issue, I injected a clean 440 Hz 5 mVrms sine signal as suggested by TP7 on the schematic. Then I followed all the test points by probing them with a scope and everything agreed within 10% with the schematic. The only weird thing was the amplitude on the output of the reverb tank: the schematic said "10 mVac min" and I was getting like 200 mVrms. I spent hours trying to test everything in the circuit, all being normal and I still had no reverb effect. Finally I decided to remove the reverb tank from the case, it was all glued in an ugly way with double sided tape and foam. What I noticed was that the laminations on each side of the tank were touching the paper case. So I removed the metal base from the paper case which was also glued in an awful way. Finally with the "naked" reverb tank I had reverb in the output sound ! The amplitude at the output of the tank went down to 20 mVrms which seems a lot closer to "10 mVac min". So I guess the problem was really mechanical and not electronic, by touching the case, the tank must have been propagating the wave in a different mode. I carefully reassembled everything and it kept working
In the last picture you'll find an oscilloscope screen shot with the sound starting to come in the tank and getting out around 25 ms later. If anyone has experience with reverb tanks, can you tell me if it looks as it should ?
Another question I have is about the volume. On the schematic you can see that the input can follow two different paths, clean and overdrive. After the channel switch S1, the signal is buffered by U3B and its output should be 410 mVrms. Obviously this figure will depend on the position on volume and gain pots. With the overdrive channel, if I set the gain on 1 (no visible distortion) and the volume about in the middle, TP13 is indeed around 400 mVrms. Now if I switch to the clean channel and I vary the volume knob,
TP13 only goes from 0 to 100 mVrms when the volume is at the max. Do you think it is normal for the clean channel to be less loud than the overdrive or is something defective in the circuit ? The clean channel is only composed of one op amp U1A and some passive components. I don't understand the circuit around U1A, but I tried to simulate it with LTspice and I get at most 80 mVrms on the output wich agrees with my measurements.
Schematic:
http://support.fender.com/schematics/guitar_amplifiers/Frontman_15G_15R_schematic.pdfDifferent amp but the same reverb circuit which is absent from the first schematic:
http://support.fender.com/schematics/guitar_amplifiers/Bullet_Reverb_schematic.pdf
