Hello guys, I have a problem with my Fender Stage 100 and I think it is the power transformer but I'm not sure. If I move slightly the secondary cables toward the transformer I get noise at the loudspeaker. I mean it dramatically interrupts with the magnetic field.
Also, I made measurements of the secondary cables of the transformer when disconnected from the board.
The results are:
Red 11.6 VAC
Red 31.9 VAC
Yellow 10.2 VAC
Blue 11.2 VAC
Blue 14.6 VAC
Brown 1.5 VAC
I guess my transformer has gone bad? The two reds shouldn't be the same and the yellow zero volts?
Please, I would appreciate any help.
Thanks!
