IIRC there are a number of bi pin fuses mounted on the PCB's , check those are okay and of course the power rails are good if not done already. Also the front panel switches /Pots are all quite ancient now and could be well oxidized, so try operating them a number of times while observing the output for any notable response. A clean/lube of the switches would be in order at least.
