Author Topic: Find a replacement relay by pin spacing?  (Read 1208 times)
Offline 5ubtleTopic starter
« on: June 23, 2023, 10:15:32 pm »
Hi all,  First post.
I want to identify a replacement SPDT relay based upon it's mechanical properties (pin spacing).  I don't find this as a search parameter at Newark.
How can I find a relay with the pin locations as shown in my attached sketch?  This will be a repair part for a 30 year old garage door opener.  There are no markings on the relay (no manufacturer, no PN, no logo, nothing).  Coil voltage is 24VDC.  Contacts need to control 1A at 120VAC.
Offline floobydust
Re: Find a replacement relay by pin spacing?
« Reply #1 on: June 23, 2023, 10:20:54 pm »
That is a standard package relay. But nothing in a garage door opener is rated only 1A.
They are typically cube relays like Omron G5LE-1-DC24 or Song Chuan 833H-1C-C 24VDC sealed, I have not tried Songle as a cheap replacement.
I change all 3 - lights, motor fwd, rev. for the amount of hassle it is.
« Reply #2 on: June 23, 2023, 10:35:01 pm »
I have 0.6 inch between the pins along the long axis.  The relays you suggested have 0.5 inch on that dimension.  Is that "as close as I will find"?
Offline floobydust
« Reply #3 on: June 23, 2023, 11:30:03 pm »
Double check the measurement, I've never seen a longer relay in that form factor and with no markings or part number.
« Reply #4 on: June 23, 2023, 11:32:36 pm »
The measurement is correct.
« Last Edit: June 23, 2023, 11:38:44 pm by 5ubtle »
Offline pickle9000
« Reply #5 on: June 23, 2023, 11:42:26 pm »
Looks like a standard automotive footprint.
Offline floobydust
« Reply #6 on: June 24, 2023, 12:19:19 am »
It's a longer cube relay with the extra 0.1" and that might be done for extra isolation voltage or current rating.
But sorry no luck at all finding one. Tried a search looking at the relay size such as overall length. It would have to be longer than the standard cube relay's 20-22.5mm.
TE Connectivity, they have bought out many old relay manufacturers and have the oddballs. But their website is a form of hell.
I'd just extend the coil pins on a standard cube relay it if can be done without creating a spacings/safety issue.
The following users thanked this post: 5ubtle
Offline squadchannel
  • Country: jp
  • deepl translate user
« Reply #7 on: July 23, 2024, 07:38:22 am »
The TE catalog is easy to understand.
For power relays:https://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=1-1773969-4&DocType=DS&DocLang=English&DocFilename=ENG_DS_1-1773969-4_2002.pdf
In the case of relays, there is usually a "de facto standard" package.
Offline floobydust
« Reply #8 on: July 23, 2024, 07:00:22 pm »
I didn't see anything by TE in that catalogue that matches OP's oddball 0.6" spacing. Even the Schrack stuff (which is from Mars) they use their own distinct oddball package most of the time.
