Hahaha!
The service manual is attached.
Page 051, DMM PCB. Top right corner. T1.
DMMV constant +5v DC
DMMP high (5vDC) when DMM is off. Low (0v) when DMM is on.
DMMP could also be a pulse. But as it is my scope I cannot test it. Will need another scope for that.
Q10 was faulty. I am waiting it to arrive from Digikey in a week or so.
The story is. I bought it from a retired gentleman. The main pcb had a pretty bad electrolytic leak and the DMM had a battery leak and he used it for a while like this. The scope still works just fine. But the coils on the main board were humming really loud. So I am replacing all coils, all caps, diodes, regulators on the power block.
The transformer may never be faulty, but myself on the process of testing it may have damaged it. Sadly.
On basic resistance test the coil 2-4 has 3ohms, 1-5 has 5ohms and 7-9 has 10ohms. Also there is not short between the coils. So it may still be just fine. But not a 100% sure.
The BOM refers to it as S1673305. No voltage. Schematics have no voltage as well.
So I am hoping to have some good news when the new component arrive.
