The signal generator finally arrived and I finally tested the transformer
To start with a Sine, 15khz, 5v straight to my scope reads as a 0.5v as well as on my multimeter. I am not sure why, but seems the signal generator says it generates at 5v but what comes out is 0.5v.
So all tests have been made with this 5v / 0.5v reading
@15khz input on pins 1-5 outputs 0.82v on pins 6-8
@15khz, 5v input on pins 2-4 outputs 0.82v on pins 6-8
If I raise the frequency to peak output
@190khz, 5v input on pins 1-5 outputs 1.93v on pins 6-8
@190khz, 5v input on pins 2-4 outputs 0.9v on pins 6-8
I cannot really scope the DMM board as it is part of the Scope.
Would it be a good idea to attach a 5v power supply to DMMV and see if it oscillates and if it does capture the frequency?
I imagine the DMMP does not have an influence in the oscillation as it seems to be there just to get Q10 active and divert the current away from Q9.
