Author Topic: Finding a similar replacement for an older rocker switch  (Read 541 times)
Offline toliTopic starter
  • Country: il
« on: November 06, 2021, 03:26:27 pm »
I've got an older TTi lab power supply (PL330QMT) whose power switch is no longer working. The original part number (61115916, DPST switch) seems to be from this series:
https://www.carlingtech.com/rocker-switches-611-621-series
I've attached a couple of pictures at the end of this post too.
I have other switches of similar size that can be used with the same cutout of the front panel. However, before I replace it with something different, I'd like to see if I can have something that would also look identical to the original.
Anyone has any idea where (if) a direct replacement, or something that will be as similar as possible could be found?
Thanks.
EDIT:
« Last Edit: November 06, 2021, 03:34:44 pm by toli »
My DIY blog (mostly electronics/stereo related):
http://tolisdiy.com/
Offline Renate
Re: Finding a similar replacement for an older rocker switch
« Reply #1 on: November 09, 2021, 06:55:00 pm »
Paddle switches seem to have fallen out of favor.
If you instead look for rocker switches in 0.5" x 0.75" you'll see a zillion of them for less than $5.
The good thing is that when you eventually find your heirloom switch it will only take you 5 minutes to swap out anyway.
