Electronics => Repair => Topic started by: cslee on April 19, 2017, 01:32:12 pm
Hello, everyone!
I've recently acquired an Agilent N4010A (Wireless Connectivity Test Set) and an N4011A (MIMO/Multi-Port Adapter).
But, N4011A did not come with a cable (Part Number N4011-21002 or N4011-61804).
The cable is necessary to connect N4010A and N4011A, but the price is about $300 if I order from Keysight part store.
Both of connectors at the rear panels are DB25 female type.
So, I'm planning to try DB25 male-to-male cable, but not sure whether the genuine cable has some pin crosses.
The cable with which I will try is http://assmann.us/specs/AK401-2.pdf (http://assmann.us/specs/AK401-2.pdf)
Do you guys have any suggestion on this try?
Cheers,
Chungsub
