Im trying to fix the front end on one of the channels of my scope, from what I can tell the transistors and diodes in this pic are the problem... doing resistance and diode tests in circuit gives crazy values compared to the other three channels.
So far I have figured out one transistor is going to be a 2sk508-52 jfet, and it is definately bad, out of circuit a transistor tester reads it as 2 resistors!
The other three transistors labeled 3em with a sideways 4? are some sort of MMBTH10's but the sideways 4 is throwing me off I think they may be MMBTH10−04LT1G's but I am not sure.... The weird thing is in circuit only one leg of all three transistors was testing strange compared to the other three channels, using diode drop and resistance on a DMM, so I took them out. Oddly out of circuit diode drop/resistance tests doesn't work at all, the dmm says overload, but the transistor tester shows everyone with a VBE of 700mv and 6na IC.
The two diodes are labeled C1, I think they are NXP 43v zeners, but I'm not sure. I need to put my power supply back together because I don't have any other 50v source to test them with.
