This post is semi-related to the thread I started for an old pick and place machine I got recently.
https://www.eevblog.com/forum/reviews/finally-have-a-pick-and-place-on-the-way-quad-ivc/Getting it up and running has revealed at least one bad PCB that is part of the vision system critical to the operation. In general, I would not bother reviving old-tech except for the fun of it. In this case, finding a fault in the board is quite important for me to be able to assemble PCB's without having to spend the money on contract manufacturing. This machine is full of PCBs that are hard to find so sharpening my PCB repair skills may be worth it.
The board is an ICOS MVS922 which is a controller that goes into an ISA slot of an industrial PC running wIn XP PRO. The original configuration was DOS based, the XP is an update that happened around 2009. The exact function of the board is unknown and I have not found any documentation at all. The company was purchased by KLA-Tencor and I have reached out to them to see if an archive exists. This is a commercial/industrial product so there is at least a small chance that some helpful docs exist. I have done some troubleshooting before, but my day to day is designing circuits. Without a schematic or block diagram it is hard to know where to start. The PC does not flag it as a problem, but the software cannot get a response from it. That is all I know. It worked for some time with the exact same PC configuration.
I pulled some of the datasheet on the components which are largely common discreet 5v logic, RS-485 differential driver/receivers, and some memory. I did a thorough visual inspection under a microscope. Everything looks good, no evidence of previous repairs. No thermal damage or cracks.
Checked the +5v to GND at around 170 Ohms which seemed a little low but not alarming. When powered up, it pulls 400ma (2 watts) which seems a little high with nothing connected to the I/O but not alarming. Nothing gets hot enough to find with my fingers and I do not have a thermal camera.
Powered it up outside of the PC and checked to verify the input to output relationships on the logic chips as best I could based on the data sheets. Nothing seems abnormal. Its hard to check flip-flops and shift registers in a simple way.
The chips that have the HEX value labels are unkown. At this time, I have not removed the stickers because these have a trade-in value if I were to replace it. A company called PPM keeps these and repairs them for $500 plus your trade in. Without a trade, it costs a lot more. If anyone has a guess what those might be doing without pulling the stickers, I am all ears.
Any suggestions where to go from here?
