Author Topic: Finding pots for Tektronix 2205 scope  (Read 600 times)
Offline larrybudTopic starter
« on: May 05, 2023, 06:43:51 pm »
I would like to replace the pots for the hor/ver position dials, and the other front panel pots. I cleaned them, and they "work" but the value of the pots moves pretty wildly just when barely touching the knob. I suspect the "springiness" of the contacts inside are losing their luster.
I have the values of the pots, there's only 2 unique ones, and I have the manufacture part number out of the service manual, but I have no idea how to find these. They obviously need to fit the pin layout AND for the knob to fit inside one. Any help would be appreciated:
Pot 1: PP1700HGA0A4110 (10K 0.2W)
Pot 2: PP17/000HFAQA234 (470 OHM, 0.2W)
They appear to be the same except for the value.
Offline PwrElectronics
Re: Finding pots for Tektronix 2205 scope
« Reply #1 on: May 05, 2023, 07:36:49 pm »
Looks like the datasheet for those can be found here:
https://www.datasheetarchive.com/pdf/download.php?id=d173222a191887dcc8af9091d0182e1d862f78&type=O&term=753504%252F02%252Fpp17
Made by Mepcopal.  Searching for that company only seems to turn up random vendors with some perhaps old stock parts and didn't find mfg website (but I did not search too hard).
You may need to dig through product offerings of mfg of pots looking to find something matching.
Another possibility is this place has them:
https://www.sphere.bc.ca/test/tekparts.html
Good luck.
EDIT:  I did find some reference to Mepcopal being acquired by BC Components and BC is now part of Vishay.  Mepcopal apparently was a joint venture of Phillips and Copal back when.  Looking at Vishay products I didn't see anything looks like what you have though.
EDIT #2:  I must be bored this Friday afternoon...  So, found this BC Component catalog from 1999.  Look on pages 140 and 141.  Those look a lot like your parts.  But, renamed series/pns...
https://xonstorage.blob.core.windows.net/pdf/cgi-bin/PDF/Phycom/BCC.pdf
Searching on CRC17 and MRC17 modules turns up some hits too but not sure if these are available other than old stock either.
« Last Edit: May 05, 2023, 08:08:50 pm by PwrElectronics »
« Reply #2 on: May 06, 2023, 12:44:10 pm »
You da man! Thanks for your time! The MRC17 looks exactly like it.
What did you search to find it?
