Electronics => Repair => Topic started by: NiaDebesis on March 19, 2023, 12:40:08 am
Title: finding suitable mosfet substitute
Post by: NiaDebesis on March 19, 2023, 12:40:08 am
Hi guys,
I am repairing an old instrument that has all the pwoer mosfet gone..
I have to find suitable replacement for the PSU.
1) The old one is 2SK2372 and the substitute will be IXTQ26N50P-ND
2) The old one is 2SK2488 and the substitute will be IXFH12N100P-ND
Do you think that they will work? I had a limited choice because I have to order another ton of components and this are the only one that I think that are right.
Both mosfets are the used in a switching PSU.
Title: Re: finding suitable mosfet substitute
Post by: NiaDebesis on March 19, 2023, 08:30:25 am
Can anyone help please?
Post by: DeepLink on March 19, 2023, 08:49:07 am
Also found these alternatives
For 2SK2372
2SK3522
FMH23N50E
IRFP460
For 2SK2488
FMH09N90E
Post by: NiaDebesis on March 19, 2023, 09:21:52 am
For 2SK2372
2SK3522
FMH23N50E
IRFP460
For 2SK2488
FMH09N90E
Unfortualy the only options I have are the one I listed, no one of all the above mentioned MOSFET are available, only the IRFP460 but the VGSS is +-20 instead of +- 30 of the original.
What do you think about the replacement I found?
Post by: DavidAlfa on March 19, 2023, 01:51:44 pm
* 30n60 * MOSFET
https://www.mouser.es/c/ds/semiconductors/discrete-semiconductors/transistors/mosfet/?q=30n60 (https://www.mouser.es/c/ds/semiconductors/discrete-semiconductors/transistors/mosfet/?q=30n60)
SiHP30N60E
FCP130N60
IXTH30N60P
Post by: DeepLink on March 19, 2023, 03:49:26 pm
The 2 alternatives you mentioned is comparable with the original types
When used in SMPS, you have to look at capacitance, gate charge and timing as well as the "normal" parameters like Voltage, Current
