Author Topic: Firmware Dump Elgato Stream Deck XL anyone?  (Read 387 times)
Offline 0xPITTopic starter
« on: October 23, 2024, 01:34:30 pm »
Hi there,
I'm trying to repair an unresponsive Elgato Stream Deck XL with OK power supplies,
and was wondering if anyone could dump me their flash contents? The flash is a XT25F32B.
Thanks
pit
Offline zhanster
  • Country: ua
Re: Firmware Dump Elgato Stream Deck XL anyone?
« Reply #1 on: January 15, 2025, 01:45:12 pm »
Hey, i have dump from my Stream Deck 5x3. There is was the same XT25F32B. But in my case this one XT25F32B was with broken addresses, so i replace it with another one.
So if you steel need this firmware, i can sell it to you by symbolic 10 dollars ;)
zhan.krivoy@gmail.com
« Reply #2 on: January 15, 2025, 02:28:53 pm »
Thanks, I've completed the repair in the meantime.
Root cause were both DC/DC converters (TLV62568DBVR) – see picture attached
Also, not sure if it's a good idea or in the spirit of this forum to ask for money, esp. for software you obtained the way you did.
Online coromonadalix
« Reply #3 on: January 15, 2025, 07:33:01 pm »
you have free nuvoton tools  if the mcu is a nuvoton  to make dumps  on other threads
and or for the XT25F32B  since its an SPI device,   you have cheap programmers who clip on it, hold the mcu in reset and normally you should be able to dump the eeprom
https://github.com/Droid-MAX/SNANDer
https://www.alibaba.com/product-detail/XP866-USB-SPI-Programmer-Full-Set_1600868985830.html
« Last Edit: January 15, 2025, 07:39:25 pm by coromonadalix »
