Author Topic: First repair! 3comm 8 port gibabit switch  (Read 2096 times)
Offline apellyTopic starter
  • Probe
« on: November 05, 2013, 01:48:42 am »
OK, the subject oversells this somewhat, but I'm still bloody stoked.
I was running out of ethernet ports on the switch where I sit to do most of my tinkering, and I remembered I had a broken 3comm switch. The power leds came on, but it didn't function. If it was something simple I might save 50 bucks. It used to get quite warm, so I opened the thing and was going to replace the electrolytics. Had new ones lined up and everything. Then I remembered: "Rule 1: Thou shalt check voltages!. " Thanks Dave.
Bloody plug pack was screwed. This has happened before, but it never dawned on me this time. A rummage around the junk box came up with two replacement candidates (with wrong connectors of course). Turns out one of those was buggered too, so I don't know what possibly functional piece of kit I threw out when that failed. Sigh.
Anyway. Thou shalt check voltages!
Re: First repair! 3comm 8 port gibabit switch
« Reply #1 on: November 05, 2013, 06:41:07 pm »
Still change those caps though, they probably are dying as well if the wall wart has been cooking them with ripple for a while along with the built in toaster oven.
