I think I had a similar fault 18 months ago and ended up replacing the motor control board 426974 because I stuffed up and fried the whole board while testing.
The machine starts any cycle as normal, but periodically shuts off and will not turn back on for a while, even when mains is disconnected for a minute. After several minutes, it will, and I can continue the cycle by advancing to where I think it stopped... until I reach the final spin dry cycle - Once the motor gets up a couple hundred RPM, it shuts off again. Seems to me a current draw issue?
I suspect its a power supply issue but not sure which components to check. There is a burn mark beside one of the fuses but it measures closed even after the unit faults.
Does anyone have a link to a circuit diagram?
What should I be looking at?
I am aware of the water damage to the board. I have checked every track and they all have continuity.
(edited to better explain)
