I've got this Loudbox Mini amp on the bench, it belongs to my girlfriend's dad so I offered to take a look at what I assumed would be a simple problem. He says it worked perfectly the last time he used it then he turned it on a few weeks later and there was a loud continuous static noise. I found the schematic (attached) and started poking around, eventually tracing the white noise as coming from the CH2 Dry node in the preamp which is the section that handles the mic input. The mic input does seem to work but the noise is there, and it is affected slightly by the gain pot on that channel and by the high and low tone controls. I desoldered one side of C29 to isolate the input and confirmed that made very little difference, then I desoldered one side of C71 and now the white noise is completely gone and the amp is working, . Ok so I decide U4 must be faulty since it's the only IC in that block so I scrounged around and found one on a scrap board and swapped it in, no change, the static is still there!
A friend suggested checking the gain pot so I did, it seems to be fine, ranges from about 2R to 48k when I rotate it which seems about right for a pair of 100k tracks in parallel, why they used a double pot I don't know. Scoped the supply rails and they look ok, nothing out of the ordinary there. This has got me pretty well stumped, there's only one active element in that entire block and I already swapped it, I used a salvaged IC so I suppose it's possible it's also bad but it seems unlikely I'd have one with exactly the same fault. I'm wondering if there's some other path I'm not considering where having C71 in the circuit could cause white noise.
