Author Topic: Fitbit Charge HR charger pinout  (Read 7398 times)
Offline 0b01010011Topic starter
« on: December 05, 2016, 05:45:02 am »
Hi guys,
The wife has lost her Fitbit Charge HR charger lead, and has asked me to see if I can at least charge it until she gets another one.
I did do some searching and could not find the pinout - there are some of other Fitbits but seems they all have different charge connectors.  What I am after is the pinout of the one in the attached image, circled in red.  I'm pretty sure one will be 5v and one will be GND.
Thank you...
Offline brainwash
    • Hack Correlation
Re: Fitbit Charge HR charger pinout
« Reply #1 on: December 05, 2016, 11:34:07 am »
I normally run a diode test on the device and if I see a conduction path (600mV or so) then it usually means that the polarity is reversed (protection diode). Then I would feed 5V at a very small current (10-20mA) to see if anything breaks.
However a google search shows this: https://community.fitbit.com/t5/Charge-HR/Temporary-USB-charge-lead/td-p/732222
"I just tested my charging cable and if I hold the cable with the bend/notch to the top the left pin is negative and the right is positive according to my voltmeter."
Make sure you current-limit everything before testing.
Offline Postal666
« Reply #2 on: December 05, 2016, 08:29:50 pm »
Please excuse the crude MS Paint...
Both pins show as short (both directions) in diode mode.
Vcc is 2 Ohms
Hope that helps
« Reply #3 on: December 05, 2016, 10:19:10 pm »
Fantastic thanks for the info guys, yes if I didn't get any info I would have tried a current limited PSU at first, but as you suggest brainwash a diode test is a good idea so I'll remember that for the future.
I am guessing the FitBit must have either reverse diode protection or a series diode as minimum as it is possible to 'fudge' the connector backwards, not sure if it makes contact though.
Will give this a try tonight.
