Author Topic: Fix vertical hold on a monochrome monitor  (Read 996 times)
Offline rea5245
« on: June 10, 2021, 07:12:57 pm »
I have a monochrome monitor with a beautiful amber display, but I can't get the vertical hold to stay put.
It's a Magnavox 7BM623 074T. I can carefully find a sweet spot for the V Hold to stop the screen from rolling, but if I turn the computer and monitor off then on, it loses the hold and starts rolling slowly.
I've replaced all the electrolytic caps and the V Hold potentiometer. The problem remains.
Anything else I can try?
Thank you,
   Bob
Offline bob91343
Re: Fix vertical hold on a monochrome monitor
« Reply #1 on: June 11, 2021, 05:48:00 am »
You would get better results if you had a schematic.  The synchronizing pulse for the vertical oscillator is apparently weak or nonexistent.  You need to find that circuit and troubleshoot it.
Offline PKTKS
  • Country: br
« Reply #2 on: June 11, 2021, 11:15:54 am »
That is true..
When you *CAN*  pause the rolling even for a second...
it  means the local oscillator is perfect
but you have problem w/the sync integrator..
Just try to find hard that part of the circuit...
The fault should be at the integrator.
Paul
Offline rea5245
« Reply #3 on: June 11, 2021, 12:00:43 pm »
Yeah. Alas, I do not, and Google can't find one either.
Offline themadhippy
« Reply #4 on: June 11, 2021, 12:13:24 pm »
I thought the correct fix for a rolling crt display was a sharp thump on case,or does that only apply to televisions?
Offline rea5245
« Reply #5 on: June 11, 2021, 04:32:46 pm »
Pardon my ignorance, but what is the integrator? Is it related to phase-locking with the input video signal? Is it likely to be an integrated circuit, or just some discrete components? (This monitor was manufactured in 1990. I only see one IC in it.)
- Bob
Offline PKTKS
  • Country: br
« Reply #6 on: June 11, 2021, 04:36:43 pm »
- Bob
the integrator is the modern term used to a LPF (low pass filter)
The synch pulse train is generally combined and the vertical
sync is mixed with the horizontal.. so you need to LPF the vertical
and HPF the horizontal pulses..
When they are combined in a usual stream..
Which is the likely in more old stuff CRT..
Digitally generated pulses are not like that
The integrator is just a LPF which will separate
the V synch in the SYNCH train.. (always H based freq,)
Paul
Offline rea5245
« Reply #7 on: June 11, 2021, 04:43:58 pm »
This monochrome computer monitor is driven from IBM's Monochrome Display Adapter standard, which has separate Horizontal Sync and Vertical Sync pins. So wouldn't that mean there's no need for a LPF?
Offline PKTKS
  • Country: br
« Reply #8 on: June 11, 2021, 04:53:40 pm »
That depends a lot on the circuitry
Do you have the CHIP number?  if it is a chip ..
All discrete ?
You need to carve that detail .. if you have the CHIP
controller number .. search for a usable datasheet..
old stuff is likely to be scanned in PDFs these days..
If it is really OLD  (amber stuff is old) it may be all discrete
and likely to have a mixed tech of analog and digital..
hard to say from here by guessing..
but just ONE CERTAIN:  the is a problem w/SYNCH PULSE somewhere
not tripping the local vertical oscillator properly
Paul
« Last Edit: June 11, 2021, 04:56:16 pm by PKTKS »
Offline rea5245
« Reply #9 on: June 11, 2021, 04:59:26 pm »
The only IC is a 74LS86 - a quad XOR gate. Everything else is discrete.
Offline PKTKS
  • Country: br
« Reply #10 on: June 11, 2021, 05:04:27 pm »
For that shit  you need a 4 chan scope and a lot of patience.
Paul
Offline rea5245
« Reply #11 on: June 11, 2021, 08:06:47 pm »
I'm more worried that I need more knowledge of analog electronics than I have.
- Bob
Offline BrokenYugo
« Reply #12 on: June 12, 2021, 07:21:41 pm »
Without a schematic for the forum to look at and guess the trouble point you're pretty much reduced to tracing the V sync signal and sketching out that partial schematic, and figuring out where it gets weak to pinpoint the faulty area.
Another thought, are you certain it's the monitor and not the equally old display adapter driving it? A scope of any sort will be useful here.
Offline rea5245
« Reply #13 on: June 12, 2021, 07:31:50 pm »
Well... no... now that you mention it, I guess I'm not certain. I don't have another monochrome monitor to test with the PC.
I have a scope though. What would you suggest I look at? The vertical signal, and whether it has a rock-solid frequency?
Offline BrokenYugo
« Reply #14 on: June 12, 2021, 08:07:17 pm »
Without looking up the standard my assumption (a dangerous word) would be there should be a 5V TTL signal on the port and it shouldn't be distorted much when the monitor is plugged in.
Offline Ground_Loop
« Reply #15 on: June 13, 2021, 03:20:36 am »
I had the same problem with an old computer and monitor. It turned out to be the sync signal in the computer. I had a bad CMOS logic chip. Have you tried connecting a different device to the monitor?
There's no point getting old if you don't have stories.
Offline james_s
« Reply #16 on: June 13, 2021, 04:42:27 am »
I'm not sure why you replaced the pot, if adjusting the pot affects the rolling then the pot is obviously not the problem. I do not advocate shotgun replacement of electrolytic capacitors either, much too often I've seen people replace good quality parts with the cheapest no-name Chinese junk around and then mess something else up in the process.
Are you sure the video card is producing a valid sync signal? Is the signal getting all the way to the board in the monitor? The symptom you describe is exactly what you will see if there's a bad connection somewhere and the sync signal is not getting through.
Offline vk6zgo
« Reply #17 on: June 13, 2021, 05:16:01 am »
If you have a scope, have a look at the back of the sync input socket, or the equivalent pin of a multiway socket.
If there is a signal, & it looks correct, the connector, cable, & display adaptor is ok.
You should be able to trace either a cable, or if it directly connects to the PCB, the track which runs from that point.(often, if a cable is used, it connects to the PCB, so you will end up following a track, anyway).
There may be a dry joint, or other disconnection--------if so, the signal will either disappear, or become reduced in amplitude.
If that hasn't happened, you can then probe around the device it ends up connected to.
If this is an unidentified IC, take note of the type number, then Google for it, as these often show typical circuits using the device.
Many of these monitors are fairly generic, so it also may be possible to find the schematic of a similar one.
Offline rea5245
« Reply #18 on: June 13, 2021, 01:16:10 pm »
I don't have another monitor or another PC to try it with.
On my scope, the V Sync signal seems fairly steady, but there are two odd things, and I don't know if they're significant. First, the scope (a Rigol DS1054Z) calculates the V Sync signal alternately as 50Hz and 49.5Hz. Second, if I watch the trace for several seconds, I can notice that it's slowly crawling the left. But is that really a problem with the signal, or just with how the scope is calculating and drawing it?
At the same time the scope's trace is slowly crawling, the monitor's V Hold is stable enough that the screen is not rolling.
As I mentioned before, if I turn the monitor off and on, it loses the vertical hold. If the problem is in the signal from the PC, would you expect that I could adjust the V Hold knob and stabilize the screen, then lose it by turning the monitor off and on?
Offline BrokenYugo
« Reply #19 on: June 13, 2021, 01:57:15 pm »
Did you happen to get a picture of the scope trace? Probably a monitor side problem if it looked something like this.
http://minuszerodegrees.net/mda_cga_ega/mda_sync_ver.bmp
The following users thanked this post: vk6zgo
Offline rea5245
« Reply #20 on: June 13, 2021, 02:02:49 pm »
Here's a pic of the vertical sync.
[attachimg=1]
Offline james_s
« Reply #21 on: June 13, 2021, 07:02:03 pm »
That sync signal looks fine to me, if it's crawling it's due to the trigger settings on the scope, you'll have to adjust those to get it to display properly there. The frequency readout changing is also totally normal, scopes are not precision frequency counters. The sync at whatever point you are measuring is ok, but it must be disappearing somewhere before it gets to the vertical oscillator.
Offline PKTKS
  • Country: br
« Reply #22 on: June 14, 2021, 10:38:37 am »
[attachimg=1]
Place BOTH waves using the OSC as primary trigger...
The SYNC is failing to adjust the OSC properly..
if it is deviating due to aging components *you may* see that..
Paul
Offline vk6zgo
« Reply #23 on: June 14, 2021, 01:39:26 pm »
[attachimg=1]
The 1054 should have no trouble triggering, but the very low displayed signal level may be a bit problematical.
It would probably be a good idea to reduce the volts/div so the display is say, 5 divisions in amplitude, then try retriggering.
Another idea is to reduce the time/div setting, as you don't really need to look at so many cycles.
Offline rea5245
« Reply #24 on: June 14, 2021, 01:52:30 pm »
According to the MDA spec, high voltage levels are 2.4V to 3.5V. See http://minuszerodegrees.net/oa/OA%20-%20IBM%20Monochrome%20Display%20and%20Printer%20Adapter.pdf, page 9.
I'm surprised. I would've guessed 5V. But apparently not.
Online Renate
« Reply #25 on: June 14, 2021, 02:05:40 pm »
Yes, the MDA signals are TTL which never goes to 5V, only > 2.8V
This is probably doing sync detection for H and maybe V.
You should be able to find two input pins that have nice V signals on them (also two with H).
Using two channels on the scope should show you what's what as you play with V hold control.
Offline vk6zgo
« Reply #26 on: June 15, 2021, 12:40:12 am »
It still shouldn't bother your 'scope, or the monitor, PAL syncs are 400mv, & even with noticeably lower levels monitors stay locked.
My reasoning with dropping the volts/div on the 'scope (giving more vertical divisions of the display for the same input signal) was not to do with concern about the actual sync level, but because, at least, in all the Oscilloscopes I have used, the triggering is taken after the input gain & attenuator stages.
If a larger signal appears at the trigger circuitry, it will almost universally be easier to trigger on.
'Scope triggering is also more likely to present problems at quite long time/div settings, like 10ms/div, than at, say, 2ms/div.
Have you compared the video signal out of the source with the corresponding syncs, using two 'scope channels?
Obviously, they should be in "sync".
Does the monitor pix roll vertically "as a whole", or does the vertical blanking drift w.r.t. the picture?
Offline vk6zgo
« Reply #27 on: June 15, 2021, 12:45:24 am »
In any case, checking the pins will show you what the IC is used for.
It could be something to do with the front controls, for instance, & all the sync stuff done using discrete devices.
Offline ambrosia heart
  • Country: hk
« Reply #28 on: June 15, 2021, 02:53:27 am »
Thank you,
   Bob
Search for word黑白電視故障檢修 and垂直不同步 at
https://translate.google.com/
translate them to English.  Choose left hand side third one .  Right hand side
second one. Copy 黑白電視故障檢修 and垂直不同步 to left hand side third one to translate.
This is an old book bought in 80s. Schematics are National TV.
In those day called National NOT panasonic.
I know you are unable to read chinese characters. I translate it
to you. In your cases, there are 2 situations I or II. Read it carefully.
In the top right hand corner written 黑白電視故障檢修
Comparing those waveforms :-BROKE printed in this book. Despite different
brands of black and white TVs, the working principle inovlved is
basically same. :popcorn:
1. Even rotate V.Hold, screen is still unable to be still. Horizontal
sync. is of course normal.
2.Reason:(a) integration circuit is faulty, making vertical sync.
signal unable to trigger oscillator. (b)vertical oscillation circuit
and the oscillation freq. are abnormal. (c)sync. circuit is faulty.
In spite of getting sync. the sync. signal is very weak.
3.prepare to adjust.
Rotate V. HOLD to see if
(a)after adjust., the screen is still rotating upwards or downwards.
(b)Still unable to make the screen be still at one point. This implies
the oscillation freq. is of about 60Hz, but no sync. signal inputted.
This explains why screen is rotating.
[II]
(a)Screen is rotating either upwards or downwards in one direction only. :wtf:
This implies the oscillation freq is highly distorted. In spite of the
presence of sync. signal, rotation still occurs.
4.Solution
For
When vertical oscillation circuit without sync. signal, this is due to
either integration circuit faulty or sync. pulse not inputted.
In fig. 218 either R421 open or (積分電路) resistors of integration
ciruit open or cap. shorted.  (垂直振盪):vertical oscillation
In fig. 219 is integration circuit consisting of R421-423, integraiton
caps. C421-422 and coupling diode D421. They are fautly.They all connect
to vertical oscillation transformer. If transformer,T421, primary side opens,
problem appears. Finding these words in schematics 積分電路 = integration
circuit, 垂直振盪 vertical oscillation
For [II]
This is a great distortion in vertical oscillation.
(a)screen rotates downwards, vertical osc freq. > 60Hz.
When freq. > 60Hz.
In fig. 219
(y)feedback resistor R425 and VR471 either open or greater in value.
If open, adjust V HOLD, no any change.
(z)time constant cap. C423, sawtooth charging cap C425 capacitance
decrease.
(b)screen rotates upwards, vertical osc freq. < 60Hz.
In fig.219
(v)bias feedback resistor R424 value becomes greater. Emitter time
constant resistor R426 value becomes greater. The transistor 2N3461
is bad due to increase in Icbo.
In fig.220
(w)vertical osc freq. is high due to R312 open. C301-303 capacitance
decrease. R314 and VR31 in high value or C321 capacitance decrease.
(x)vertical osc freq. is low due to R311 is greater or R305, R312,
R321,R323-324 also high in value.
(y)vertical oscillation transistor 2SC828A is bad.
