Author Topic: High pitch noise PS board  (Read 657 times)
Offline rodrigopiresTopic starter
  • Country: pt
« on: November 16, 2022, 07:51:57 pm »
Hello eneryone,
I have a Nodor kitchen extractor that is making a humming noise (I mesured around 6.4 to 6.8 kHz) all the time, even when nothing is on so it leads me to believe that its coming from the logics power supply. And the sound gets worse if I turn on the lights...
I toucht every component (with a plastic stick) and could not find the source of the sound (also no Change um sound) so no loose cores... Also did nota see any bad caps (aparently).
What could bem causing this?
Video: https://youtu.be/p3Zme8-ApkQ
« Last Edit: November 16, 2022, 07:55:07 pm by rodrigopires »
Offline srb1954
  • Retired Electronics Design Engineer
Re: High pitch noise PS board
« Reply #1 on: November 16, 2022, 09:42:42 pm »
Hello eneryone,
Have you got a scope so you can check for ripple and noise on the power supply outputs? N.B. Check that they are fully isolated from the incoming mains supply first!
The PSU control loop might have gone unstable causing it to oscillate at audio frequencies. This could cause some of the magnetic components to produce audible frequencies through magnetostrictive effects. Even the ceramic capacitors can cause noise through piezoelectric effects.
Offline edpalmer42
« Reply #2 on: November 16, 2022, 10:07:00 pm »
Take a plastic or rubber tube - size & length don't matter, just make it a convenient length.  Put one end on your ear and move the other end over the board.  You'll easily find the squealer.  Typically, it turns out to be a transformer or inductor.
  • Country: pt
« Reply #3 on: November 17, 2022, 09:48:20 pm »
So assuming its a bad control loop, the source of the problem is that 8 dip chip? Might as well change the eletrolitic caps to BE safe.
  • Country: pt
« Reply #4 on: November 17, 2022, 09:53:24 pm »
I used a plastic stick to poke every component to try to get a feel for the problem, or change in sound, but was unlucky to find the source... That tube/stethoscope looks like a great idea!
