Hi, thought I create an account here to see if anyone can help me with this weird issue.
I was moving this old Rigol scope around on the bench and heard something rattling around inside. Took it apart and found a loose component inside. It doesn't look damaged. Part number is SC566, it's a small SMD SO-8 package. I assume it's this one: ST93CS566 from manufacturer ST. Supposed to be an EEPROM.
What's this for and where is the actual component supposed to sit? I looked around for 20min and didn't find anything out the ordinary. Haven't noticed anything wrong with the scope either, could be some function that I don't use that's affected though.
Appreciate any insight.
