I've been watching Dave and lurking for a while, but this is my first post here. I just have to post, because I want to know how this is possible...
I'll start at the beginning.
I've got an old
Samsung 55" Series 9 TV, model LA55A950D1F. Besides the crappy capacitors causing the power supply to take out the backlight driver board for the local dimming LED array about 3 years into the life of the TV, it's been great. Until it got cold this year. A couple of weeks ago, I noticed that every 8 or 10 scanlines, one scanline was completely dark on the left hand side and faded up to almost full brightness by the time it reached the right hand side of the screen. My first reaction was: "Great, that looks like a deteriorating connection on a hotbar attached flex cable!" And we all know how unrepairable that is.
Anyway, as one must do, I took it apart to see what's what. A bit of basic trouble shooting and I identified the board that seemed to control the panel and reseated all the connectors. No improvement. Took the board out, inspected cleaned and Googled the part number. Found it
listed at ShopJimmy as expected. The page had this comment:
IMPORTANT: Horizontal lines on the screen are virtually NEVER caused by a bad T-con board. Horizontal lines indicate a defective LCD panel (screen). Great!
I put the board back and decided to fiddle a bit with the connectors while observing what they do. I figured I might as well learn how it works. Anyway, I noticed that various combinations of partial connections on the connectors made the horizontal lines go away. I decided to Google to see if anyone has fixed a problem like this. Almost all advice out there seems to suggest that it's a faulty panel and the TV is not worth repairing. A few people suggested replacing the T-Con board. However, I
found one YouTube video that made me go WTF? That can never work. The guy (another Dave) disconnects the panel driver ribbon cable, covers a bunch of contacts with sticky tape and that apparently fixes the picture. I chuckled at the idea and dismissed it. Further Googling didn't reveal anything more fruitful so I decided to try the sticky tape trick, expecting some cool effect as things broke in semi-deterministic ways. I used about 10mm of tape and it neatly cut out about 1/16 of the screen, stuffed the colour on about 1/8 of the screen, but low and behold, the dark scanlines were gone. I was like, WTF? Anyway, I progressively cut down the insulating bit of tape to about 3mm and everything seemed to be almost OK, except there was a hue shift in the first 1/16 or less of the screen. So, I cut of a bit more tape and stuck it on. Low and behold, it seems to be fixed and after a quick visual inspection I can not see any picture issues. I'll have to reassemble the TV and do a more through test.
Anyway, reason for the long post is to ask, how can this work? You'd think that blocking some of the data lines would cause some information to be lost and therefore degrade the picture. Does anyone have a explanation? Theories? I'm really curious about this one.
It would be educational to observe the data lines going to the panel with a scope and see how they work, but unfortunately I don't have a scope.
