Author Topic: TTP223 touch sensors self-triggering bug  (Read 1415 times)
Offline drasikTopic starter
« on: October 25, 2016, 11:29:46 am »
I have three TTP223 touch sensors connected to a power source (only VCC and GND are connected).
I intentionally didn't connect I/O pin to Arduino because I suspected that it could cause the problem (trigger the sensor by accidentally sending current to the I/O pin). One of the sensors gets triggered and starts blinking, please see the video:
https://www.dropbox.com/s/y0eeg959fybolfz/IMG_0495.MOV?dl=0
I fail to reproduce this bug consistently and don't know what causes it. I've noticed the following:
1. It happens only on the 1st and/or the 2nd sensor only if they are both connected (but after switching sensors and then assembling this same setup - sometimes this bug disappeared).
2. Thought they were too close together and were triggering each other but I tried putting other sensors even closer and it didn't happen.
I would be very grateful for any ideas on why this is happening, thanks in advance!
« Last Edit: October 25, 2016, 11:36:07 am by drasik »
