There are 2 ICs here, one op-amp and one power amp.
(0)Make sure they have been supplied with proper voltage.
(1)Download 50Hz wave file, playing it in android phone.
(2)Connecting your android phone to stereo amp RCA input.
(3)Download op-amp datasheet, finding out which pin is output.
(4)measure input and output voltage with respect to ground to see if voltage is amplified.
(5)Download power-amp datasheet, finding out which pin is input.
(6)measure power-amp input voltage with respect to ground , comparing it with op-amp output if they are in same value
(8)If they are not the in same value, check the coupling capacitor capacitance located between them.
(9)measure power-amp output voltage with respect to ground to see if voltage is amplified.
Never use this amp. except you are at home.
The power amp IC will short and burn easily.
The fuse did not burn
and the IC kept burning in yellow colour.
How horrible it was.
If you want your house on fire,
use it.
I bought this cheap amp in Hong Kong in Kwun Tong
plaza 3 floor in 1998
and never forgot this scene.
