Author Topic: Fixing the 7-segment LED of Sony sound system  (Read 234 times)
Offline prabhatkarpe4Topic starter
  • Country: in
« on: October 14, 2024, 03:20:25 pm »
I have one Sony 5.1 sound system but its 7-segment LED display is not working properly because the numbers (volume level) are not showing up completely and all the segments don't light up. Sometimes, the whole display shows nothing at all.
I need to know whether the LED driver IC (PTC 6955) is gone?
I would also like to know what the bus lines (CL, CE, DO, DI, SBY... ACF) are on the board for?
What is the connector with the labels RES, P4, VSS, PA0, and VDD for?
There is another chip HT48F50E, and could that be damaged?
The model number of the sound system is SA-WID7.
I have attached the snapshots of the chip and PCB.
