Author Topic: Fixing the RF front end of a spectrum analyzer - Siglent SSA 3021X  (Read 1952 times)
Offline Mach1Topic starter
Hi EEVblog members,
A spectrum analyzer RF front end can be easily damaged caused by long standing, low-frequency harmonics contents. The wide use of motor drive and DC-DC converters makes it even easier to damage a spectrum analyzer if you are not being careful. I recently damaged and later fixed the front end of my Siglent SSA 3021X and recorded the process. For those who have suffered from similar problems and got frustrated by the cost and lead time of having the unit repaired, check out how to fix the RF front end of a spectrum analyzer.
For those who enjoy reading, check http://emccompliance.co.uk/fixing-and-protecting-the-rf-input-of-a-spectrum-analyzer
For those who enjoy watching, check
Happy fixing
Mach1design
« Last Edit: July 05, 2021, 03:58:29 pm by Mach1 »
The following users thanked this post: xrunner, tautech, TurboTom, syau, Trader
Offline inaxeon
  • mattmillman.com
    • Matt's Tech Pages
Re: Fixing the RF front end of a spectrum analyzer - Siglent SSA 3021X
« Reply #1 on: December 21, 2021, 02:00:11 pm »
I just managed to do the same thing to my SSA 3075X Plus, which err, costs quite a lot more.
Using an RF current transformer on a low powered DC setup. Literally the inrush current of charging a 470uF capacitor with the positive wire passing through the transformer was enough to blow the analyser input. I am absolutely astonished! I would not have expected it!
I will be buying that Tekbox transient supressor too. In the mean time I have reached out to Siglent. I hope they'll be as kind to me as they were to you.
Offline Jester
« Reply #2 on: December 21, 2021, 03:40:21 pm »
What are the part numbers of the components that you replaced?
Offline inaxeon
  • mattmillman.com
    • Matt's Tech Pages
« Reply #3 on: December 21, 2021, 04:41:58 pm »
I meant that I've blown mine. Not fixed yet. Mach1 states that he replaced:
MASWSS0181TR-3000 (RF Switch)
BAR63-02V (Diode)
BZX84J-C30 (Diode)
MASWSS0181TR-3000 won't be what's in the SSA 3075X because that part is only 3GHz. Need at least 7.5GHz.
I don't know what's in mine. There doesn't seem to be any pictures or videos of the 3075X's RF deck yet either, and I'm not yet ready to break the warranty seal on mine until I hear form Siglent...
« Last Edit: December 21, 2021, 04:50:39 pm by inaxeon »
Offline oz2cpu
    • webx.dk private hobby and diy stuff
« Reply #4 on: June 10, 2022, 10:28:10 pm »
this is the latest version SSA3021X see no diodes  !!
darn it my RF input is af deaf as it can be..
Radioamateur OZ2CPU, Senior EE at Prevas
EMC RF SMPS SI PCB LAYOUT and all that stuff.
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #5 on: June 11, 2022, 12:55:13 am »
is it just the lighting or is C7 chipped and cracked?
Cheers Scott
