Author Topic: Hitachi V-1050 Scope with Frozen Volts/Division Knob  (Read 1678 times)
Roy Batty
  • Guest
« on: December 24, 2016, 11:37:41 pm »
So long, and thanks for all the fish.
« Last Edit: June 25, 2017, 03:14:52 pm by Roy Batty »
Re: Hitachi V-1050 Scope with Frozen Volts/Division Knob
« Reply #1 on: December 25, 2016, 07:39:40 pm »
I would strongly suspect either:
1. Somebody's been in there and reassembled it incorrectly. Look for traces of not so handywork.
2. The mechanism is broken or jammed by a foreign object.
Careful detective skills required so expect anything and everything. Keep your eyes open while comparing it with the working channel.
Let us know what you find as it will no doubt help others too.
Offline paul57
« Reply #2 on: January 04, 2017, 07:44:57 am »
I stumbled on this post that recommends putting a couple drops of paint thinner in there to dissolve the petrified gunk between the metal shafts:
http://forum.allaboutcircuits.com/threads/considering-upgrade-from-crusty-hitachi-v-1050-scope.130614/
My V-1050 has the same problem; I don't have any paint thinner handy but I'll try it next chance I get.  Hope it helps,
-Paul
Offline cvanc
« Reply #3 on: January 04, 2017, 12:57:06 pm »
I had the same problem on an old HP spectrum analyzer; a couple of the knobs were frozen in their current positions.
In my case the lubricant used on the (concentric) control shafts had petrified over the years.  Solution was to carefully (with a syringe) work a solvent in to break down the old lube and then just as carefully replace with new oil.  Good luck...
Offline carl_lab
« Reply #4 on: January 26, 2017, 07:44:56 pm »
Some heat by a hair dryer or a heat gun could help to make the lubricant more fluid.
When you can turn the shaft a little bit back and forth, paint thinner can work much better washing off the dirt.
