Hello everyone! First post on the forum.
I used the search function and found this thread, which I thought would be a perfect place for my question.
I am currently trying to take on an impossible repair of a flat flex cable. I say "impossible" because considering the circumstances, most people (including myself) would consider it to be impossible. However, I am not a person who easily gives up without a fight.
First of all, replacing the flat flex cable is not possible. This is because the flat flex cable is not going into a connector at both ends, but only at one end. The other end of it is going into the plasma display panel of a plasma TV that I'm trying to repair. What this means is that either I repair the flat flex cable, or the plasma panel that the cable is attached to will become scrap and end up in the landfill. This will probably happen to the rest of the TV as well since sourcing a new plasma panel for it is not easy.
Since the flat flex is not replaceable, trying to repair it is my only option before giving up.
The pitch of the conductive traces? Trust me, you don't want to know. Actually, I don't have any exact measurement of it, but it's so small that it's near impossible to see the individual traces going parallel to each other inside the flex circuit. The traces can be easily seen under a microscope of course, but the width of the traces are so small that a human hair looks big in comparison. Because of this, using a point-to-point soldering technique to patch up the broken traces is completely impossible, no matter how small the iron tip is. So I have already given up on that idea.
But before scrapping the TV, there is just one more thing I would like to try.
If the whole flat flex cable is cut off right at the problem area (all conductors are going in parallel there), then maybe I could attempt to scrape off the coating on both "ends" of the cable (where it's cut), leaving me with conductive traces on both ends, then lap soldering the whole cable together again.
The pitch of the traces is ridiculously small, but the reason I think this could perhaps work is because of the same principle as with drag soldering; you don't get any bridging between pins/traces because of the reduced surface tension of the flux. Therefore, by aligning the cable ends together so that the conductive traces align up but with a bit of overlap on every trace, maybe I could reattach the conductors and make it all work.
Since the conductors are so incredible small, any physical stress to any conductor will break it off. If that happens it's game over.
The flat flex cable has a COF on it. It's a one layer flex circuit (if it was a two layer, I wouldn't even attempt the repair). The upper side is coated with some green kind of coating acting as a solder mask, and the lower side consists of a brown-orange looking material, quite similar to the color of kapton tape. This acts as the substrate of the flex circuit. (Is it maylar, perhaps?)
I have managed to get the green coating off at one end of the cable, exposing the conductive traces. I managed to to this with only minor damage to some traces, which I think I will be able to repair.
However, I have now gotten stuck and am unsure how to proceed. Because I need to free the conductive traces from the bottom side of the flex circuit as well, leaving nothing but the exposed conductors for a length of 1 mm or so. This is the length that is to be overlapped to the other "end" of the cable that I'm reattaching to.
Now to my question.
How can I get the brown-orange bottom (mylar?) flex substrate to separate from the conductive traces without damaging the traces or accidentally solder the traces together? How are the traces bonded to the bottom flex substrate during manufacture of the flat flex cable? Is there any kind of chemical out there that can dissolve this bonding material, without causing any harm to the conductive traces? Any suggestions?
I do realize that I'm going to fail with this attempt with 99.5% certainty. If the pitch had at least been within reasonable limits, then I might have gotten away with a point-to-point patching technique with a higher chance of success. But because of the fine pitch, I consider my chances being slim to none. Still though, like I mentioned, I don't like to give up without first having a good fight.
