Author Topic: Flax Ribbon Cable Repair - Any Solution for this?  (Read 1736 times)
Offline zaoka
« on: March 07, 2016, 10:40:21 pm »
Does anybody have working solution of how to fix bad ribbon flax connection when there is a bad connection between PCB board and cable?
I used latex tubing to create pressure, however, its not reliable way to fix it...
Here is how it looks like:
Thanks
Offline sorenkir
Offline RobertBG
Re: Flax Ribbon Cable Repair - Any Solution for this?
« Reply #3 on: March 08, 2016, 06:41:42 am »
I've had some luck just carefully using a solder iron and reheating them.But its hit or miss,it either works all the time or not at all depending on what it is.
Offline SAUL BRITTO
  • Country: br
  • Don't Make a Mistake
« Reply #4 on: March 08, 2016, 09:14:24 pm »
If you don't understand portuguese just look:
Thank You, for all earth.
