Author Topic: HK 206 PC Speaker Popping Sound  (Read 533 times)
Offline bobcat2000Topic starter
« on: March 02, 2021, 01:11:28 am »
Hi Guys,
I have been using a pair of HK 206 speakers for years.  No problem no thing.  It sounds and works great.
I always turn it off by turning the volume dial when I am done listening to the speaker.
The other day, the static built-up in my butt was too high.  I got a big spark when I touched the volume dial the other day.
The speaker still work but every time I turn it on/off, it makes a big pop noise now.
I probably ran thousands of volt through the plastic knob to the pot and somewhere to the transistor and to the ground when I touched the knob the other day.
May I ask what may be broken inside?  It is old so I don't want to crack it open. I will probably break the old plastic housing.
It may not have anything look burnt inside anyway since it is still working without any problem.
Thanks!
https://www.amazon.com/Harman-Kardon-Computer-Speakers-HK206/dp/B00577RM8Y
Re: HK 206 PC Speaker Popping Sound
« Reply #1 on: March 02, 2021, 01:24:45 am »
Ah!  I found this.  There is no transistor inside.  It has a TDA 1517a amp.  So, where does it shorted to make that popping noise?  Inside the IC?
https://youtu.be/OHz-mC_xyzA
Online fzabkar
« Reply #2 on: March 02, 2021, 01:59:14 am »
https://www.nxp.com/docs/en/data-sheet/TDA1517.pdf
"No switch-on/switch-off plop (sic)"
« Reply #3 on: March 02, 2021, 04:56:56 am »
Thanks.
So, I know what goes in to the chip and what goes out from the chip.
How do I tell why there is a big pop when I turn on/off the power?
The cap discharge too much to the speakers?
