Managed to pick up a 'not working' Fluke 8550A for $100 AUD, figured it was either fixable for extending my fixing skills or worth that for parts alone. On initial visual examination found it was switched to 120v, changed that to 240v, and then had another look around in case you know what had occurred and found a blown-to-bits tant. Changed all the tants out, did a quick rail resistive check, and then got it starting up but showing a fixed distinct value per range. hmm... Then confirmed the isolator was passing the measurement bit stream via my oscilloscope, this should mean the digital backend of the ADC is good as well (at least it was reading something).
By the look of things the analog side of the ADC converter is good, everything probed good, managed to power it up off a bench +/- 15v supply and got -7.0000v on the nose on the test point - so the 'black magic' voltage reference circuit is good. I then checked the PSU, looks like either the -15v or +15v linear regulator is toast, ran very hot (they share a heatsink..). On the common failure principle, I'm going to replace all the PSU caps and linear regulators and double-check the rectifiers. Plus put the -15v regulator on its own heatsink and put in the recommended 1uf tant for stability.
I'm also replacing all the tants with new ones the next voltage spec up as I find them - given this is a known component of magic smoke doom. The board components don't look at all aged from what I can see, so I'm not going mad doing a swap out - everything I've measured is in spec, and no strange shorts so far.
I'll dummy load the PSU once everything is replaced and confirm its operation, plus resistive check all the rails on the motherboard for shorts, with emphasis on the 15v rails... Fingers crossed this should lead to a working unit.
As for how it failed, I think a heavy mains spike, given the damage on the PS side and 'weak' filtering by modern standards. But maybe someone gave it '240v surprise' whilst it was switched for 120v - wouldn't be the first time... Also, nothing wrong with the front end that I've found so far. I've also put a beefy 275v MOV across the mains for good measure.
The parts for the PSU will turn up next Thursday, by then I should have confirmed whether all the subboards are good or not.
