Author Topic: Name that component: 6x6mm, marked "100", meausres <0.2 ohm  (Read 840 times)
Offline mcovingtonTopic starter
« on: November 14, 2022, 02:26:08 am »
Not exactly a repair question, but could have been; if this belongs in a different forum, please advise.
From a defunct Wi-Fi router I salvaged a number of surface-mount parts, each rather large (maybe 6 or 7 mm square), gray ceramic, labeled "100".  I thought they might be power resistors, but they measure less than 0.2 ohm.  I haven't checked inductance.  Are they inductors?  The SM equivalent of ferrite beads?  Or what?
Online fzabkar
Re: Name that component: 6x6mm, marked "100", meausres <0.2 ohm
« Reply #1 on: November 14, 2022, 02:35:30 am »
Probably 10uH inductors (10 x 10^0). If they connect to an output pin on an adjacent IC, then they are probably part of a switchmode converter.
The following users thanked this post: mcovington
Offline TheMG
« Reply #2 on: November 14, 2022, 05:02:09 pm »
A picture is worth a thousand words.
Offline DavidAlfa
« Reply #3 on: November 14, 2022, 05:12:55 pm »
Can't understand why people keep doing this.
Make it a question, not a puzzle.
« Reply #4 on: November 14, 2022, 09:47:48 pm »
Offline DavidAlfa
« Reply #5 on: November 14, 2022, 09:53:40 pm »
That's coil. Probably 10uH.
« Reply #6 on: November 15, 2022, 12:58:10 am »
Thanks.  The large size does suggest an inductor.
Offline DavidAlfa
« Reply #7 on: November 15, 2022, 02:06:52 am »
I guess you're seeking a short?
Often it'll be one of those ceramic capacitors, but there're hundreds, so better inject some current and find the one heating up.
