Messages from Technician
Mr Delian: Hi Brendan. I jus checked that varistor with my multimeter. It's still good.
Brendan: Are you checking with ohms? My multimeter showed around 245kohm
Mr Delian: Yep. 200k ohm is correct. If there was a problem it would be open circuit
Brendan: No it should be open circuit. Only above 910v it is supposed to start "clamping" and giving a reading.
Mr Delian: Lol .no , varistors come in different ratings. There is 24v varistors , 110 v varistor 400v etc it depends on the designs of the circuit and ratings of the protected circuit in question. It had nothing to do with 910v
Mr Delian: If it was damaged it was supposed to have went to open circuit and shorted to earth preventing high voltage into the circuit thus protecting he circuit
Mr Delian : Closed circuit *
Mr Delian:
https://ourpastimes.com/test-varistor-7675090.htmlMr Delian: This explains it all for u
Brendan: You are correct in what you are saying. It is suppossed to be high reading. Then when voltage goes passed designed threshold. The value drops and creates a short. In the case of this varistor is 910v.
Brendan: Read the article you just sent me it will explain how to test
Mr Delian: Lmao Brendan I sent it to u bec u did not how test the component. So I'm helping understand how test these components
Brendan: Turn the multimeter on and set it to read resistance times 1000 ohms. Touch one meter probe to the free varistor lead and the other probe to the connected lead. Read the resistance on the meter. If it reads nearly infinite resistance, the varistor is still good. If it reads very low resistance, the varistor is blown.
Brendan: In the article
Mr Delian: simple if there is a problem it would be short circuit if there is no problem it would be open circuit. My varistor has high resistance so it's still good. But if it had low resistance it would be damaged
Mr Delian: that's what I'm telling u my varistor does not read low therefore it's good. 200k is high....0.2 ohms is low
Brendan: 200k is a short for a multimeter that can measure up to 1000v. Compare against yongamas meter
Mr Delian: Ay Brendan
Mr Delian: Make u example...Do u know across the lines on the RTG I got around 200k ohms and that's open circuit. RTG is operating and did not trip
Mr Delian: Ay Brendan I can't belive u think 200k is close circuit
Mr Delian: Anyway on my home. I give lessons 7 to 3.30. Monday to Friday anyways enjoy ur leave 2mrw
Brendan: Mmmmm. Dont think i need them. Just looking at datasheet. Resistance should be greater than 100Mohm
Brendan: Maybe look at voltage rating of varistor and then datasheet good to learn that not all varistors are the same.
Mr Delian: I never really said all varistors are the same. I've designed circuits with varistors before u cannot just use any varistors it dependant on the circuit design of course, taking into account factors.
Mr Delian: U need to read the data sheet properly, there's a lot of factors involved. As can be seen on this datasheet u sent, it will measure more than or equal to 100M ohms at: 1.1mA
2. Room temperature
3. Normal humidity for one or two hours.
This is all factor dependant and it measures differently at different conditions.
Mr Delian: Good to know the electrical engineering characteristics that plays role when reading datasheets
I guess I will have to get him sent for re-training
