Yes, excuse me I did a mistake...CC=DC, Corrente Continua(in italian)=Direct Current
I did not test the wall outlet, probably this value is quite exact. I have a Voltage Calibrator and under 20 VAC the values are about half (not exactly but about) so I can read 8-9 VAC instead 20VAC, 3-4-5 VAC instead 10 VAC, 1 VAC instead 2 VAC, 0 VAC instead 1 VAC. Above 20 VAC, the values are higher, for example 28 VAC instead 25 VAC, 55 VAC instead 50 VAC, 105 instead 100 VAC...probably the value of the wall outlet is acceptable but I did not measure this value...
