Author Topic: Fluke 1507 Problem  (Read 1490 times)
Offline Stijn_vTopic starter
Fluke 1507 Problem
« on: August 26, 2022, 04:27:14 pm »
My fluke 1507 isolation tester gives a wrong measurement on Voltage. It must be 0.0 V but on the screen is  -0.1 . Must i calibrate the meter or is there something broken.
Offline Black Phoenix
  • Country: hk
Re: Fluke 1507 Problem
« Reply #1 on: August 27, 2022, 11:10:17 am »
No need to calibrate. That's normal, residual voltage.
If you insert both probes and touch between them the value should go to zero.
« Reply #2 on: August 27, 2022, 01:55:31 pm »
No, when you touch the leads together it staysin -0.1 voltage.
« Reply #3 on: August 27, 2022, 02:06:33 pm »
Offline retiredcaps
« Reply #4 on: August 27, 2022, 07:22:34 pm »
I used to buy used and abused Fluke meters and one of them, when probes shorted, showed -0.2 ohms  My post from 8.5 years ago.
See post #2 at
"https://www.eevblog.com/forum/repair/multimeter-repair-time-again!-fluke-177-reads-8-ohms/"
« Last Edit: August 28, 2022, 12:03:15 am by retiredcaps »
Offline J-R
« Reply #5 on: August 27, 2022, 10:28:50 pm »
Voltage measurement accuracy specifications for that device are: 50 Hz to 400 Hz ± (% of Rdg + Digits): ±(2% + 3).
So best case the device shouldn't be trusted to within 0.3V anyway.
Supply some known inputs and see if they are correct?
« Reply #6 on: August 29, 2022, 09:35:55 am »
Must i clean the PCB? There is nothing dirt on the pcb ?
Offline CapLeaker
« Reply #7 on: August 29, 2022, 10:42:59 am »
Cleaning the board with 99% alcohol is a cheap investment. I’ d do the same thing if it would be mine. retiredcaps fixed his by cleaning the board twice. Hopefully it will fix yours too…
I’ve got a Fluke 178 when they came out over 20 years ago. So far so good, never missed a beat and is still within spec.
Offline J-R
« Reply #8 on: August 29, 2022, 11:15:50 pm »
There is nothing wrong with it, why "fix" it until it's really broken??
