Author Topic: FLUKE 1750 Operation Problems - Repair  (Read 431 times)
Offline EDERTopic starter
  • Country: pe
« on: November 10, 2023, 02:26:44 am »
Good evening friends, please I would appreciate your support if someone has had the same thing happen to them with a FLUKE 1750 device, the current problem is that it does not initialize correctly (only the green power LED turns on), I measured the voltage at the terminal block where the battery is connected. internal and the voltage is 0VDC. I will appreciate your comments
Offline Vovk_Z
  • Country: ua
Re: FLUKE 1750 Operation Problems - Repair
« Reply #1 on: November 10, 2023, 06:05:20 am »
In-circuit ESR-meter could help a lot with testing electrolyte caps. Though they look fine they still may fail from age. Next step - check all semiconductors and PWM ICs (LNK304 etc).
« Last Edit: November 10, 2023, 06:07:26 am by Vovk_Z »
The following users thanked this post: EDER
