Author Topic: Fluke 177 Meter Dead  (Read 1564 times)
Offline Manoj SooryaTopic starter
  • Country: in
« on: September 29, 2018, 09:18:56 am »
Sir,
My Fluke 177 is not display nothing. It suddenly happen. Battery is good.
There is a chip name LT511 24351.. any datasheet of this chip? I think the problem with this chip.
and any link to purchase a new chip from ebay or some other site?
Thanking you
Manoj Soorya
Offline retiredcaps
Re: Fluke 177 Meter Dead
« Reply #1 on: September 29, 2018, 06:50:37 pm »
Q1) When you turn on the meter to DCV, does it show anything on the lcd?    Does it show 0.000 or nothing on the lcd?
Q2) Did you try a fresh new battery?
Q3) Can you post clear focused pictures of your pcb? both sides please.
Q4) If you hookup the 177 to a DC power supply, how much current does it draw?
Offline t1d
« Reply #2 on: October 01, 2018, 10:22:23 am »
Happened suddenly? Under what conditions? Did you just blow a fuse?
Offline retiredcaps
« Reply #3 on: October 02, 2018, 03:03:55 am »
The fuse in Fluke handheld multimeters only protect the current ranges.  A bad fuse is likely not the problem here.
