Hi guys,
Dropped this post to the test equipment section, then realised that there was actually a "Repair" section. Not really sure which one it should be in but here goes:
My trusty Fluke 179 AC Range stopped working after another employee "borrowed" it! I've had this meter for many years and have never had a single issue with it. Just goes to prove the old adage "Don't lend out your tools!".
I need to get this fixed pronto as I use it all the time. If I measure mains voltage it only reads a few mV. DC volts measure ok, resistance measurements are also ok. I'm thinking that a diode bridge is most likely blown out.
However, before I take it apart blind I thought it worth getting some advice from the guys in the know! What should I be looking for - or better, does anyone know what is causing this fault?
Please help - and thanks in advance!
