Put in some test leads and short them- value should go down.
Other test: Move the multimeter to a different location and check if value changes- might pick up some radiation from nearby devices.
Edit: My U1272A tells me about 12mV in ACV mode, and about 60mV in ACmV mode with open connectors, so it is not unnormal to get some results. I can try to look later at my 179 at work how that behaves in this regard.
