Update...
The signal lamps/bulbs on NGRE unit are on 48 V AC, replacement is difficult to find, last time saw that kind
of indicators on old large scale crossbar telephone switching units, guess 45 years ago
On the second unit 2 of total 4 indicators are with broken glass.
Perhaps "hard landing" during the times before the units reach me.
It was possible to do "the surgery" on old indicators and now the 5K6 SMD R and white LED are doing the job.
The 50 Hz can be noted, but guess half duty cycle is benefit here
The cooling vents need some fresh oil in any case, now on both units all 3 vents are starting smooth and run
about the same time after the switch off. Recommended to all owners of similar units to open and check the
cooling, you may hear the vents running, but that can be only one of three.
Can put some internal pictures, in case someone is interested.
