Hello. - Hello.
Attached is a picture of the electrolytic condenser information mounted on the power supply board.
There are two types of power supply boards. One with an electrolytic condenser of 10uF/50V and the other with 47uF/50V. (The part described on line 2)
We recommend replacing all electrolytic condensers on this board except the 470uF/630V. The total number of capacitors is 40.
The defective LM358 is caused by a leaking electrolytic capacitor (220uF/25V) attached to the sub-board above it. Therefore, if the LM358 is defective, the surrounding components should also be checked and replaced.
There was a mistake in the text, and the following is the corrected content.
condenser => Capacitor
47uF/50V=>47uF/63V
