Author Topic: Panel Visonic alguien que lo trabaje o lo conozca  (Read 364 times)
Offline sergio06
  • Country: ar
« on: April 12, 2019, 03:36:14 pm »
Hola, tengo una alarma vieja es una Visonic Powermax Espress se bloqueo me sale P1: N2: N3 queria saber si alguien sabe como desbloquearla..
Saludos cordiales
« Last Edit: April 12, 2019, 05:13:29 pm by sergio06 »
Offline shakalnokturn
Re: Panel Visonic alguien que lo trabaje o lo conozca
« Reply #1 on: April 13, 2019, 12:31:36 pm »
HolĂ . Ingles aqui por favor...
Soft Reset
A Soft-Reset will not reset the master installer code or user code.  A soft-reset will reset the zone programming etc. All devices will be deleted.
To perform the Reset:
    Enter Installer Mode.
    Scroll through the menus until you see FACTORY DEFLT, Press <OK>.
    Display will show <OK> to restore, Press <OK>.
    Display will show ENTER CODE, enter the master installer code.
    Display will show PLEASE WAIT... for a short time, after which the factory defaults will have loaded.
    The display will revert to FACTORY DEFLT.
Hard-Reset
A Hard-Reset will reset the Master installer code to 9999 and the user code to 1111.
To perform a hard-reset on the Powermax Pro control panel;
    Remove the mains power to the control panel.
    Open the control panel and disconnect the battery.
    Identify the 3 pins marked DEF
    Fit a jumper across the D and E pins
    Apply battery power to the panel for approximately 10 seconds.
    Remove battery power from the panel.
    Remove the jumper from the D and E pins.
    Re-connect the battery.
    Close the panel and apply mains power.
