Author Topic: Fluke 187 failure  (Read 7276 times)
Offline alextTopic starter
  • Country: hu
Re: Fluke 187 failure
« Reply #25 on: February 18, 2017, 03:53:20 pm »
they were parallel,just the middle ones were twisted 180 degrees
Offline WackyGerman
« Reply #26 on: February 18, 2017, 03:55:04 pm »
ok does the multimeter work now ?
  • Country: hu
« Reply #27 on: February 18, 2017, 03:56:57 pm »
i have to resolder the holder of the 10amp fuse first since it came off when i pulled the fuse out to check it  :palm: :palm:
Offline WackyGerman
« Reply #28 on: February 18, 2017, 03:59:08 pm »
Ok , shit happens
  • Country: hu
« Reply #29 on: February 18, 2017, 04:03:49 pm »
yup,the third shit so far  :palm: it starts to piss me off :scared:
« Last Edit: February 18, 2017, 04:06:23 pm by alext »
Offline WackyGerman
« Reply #30 on: February 18, 2017, 04:05:49 pm »
Murphy s law again
  • Country: hu
« Reply #31 on: February 19, 2017, 11:42:09 am »
it turns out that after i glued a tiny crack on the inside of the knob i assembled it together too fast and the superglue did not dried completely and the evapored glue made a tiny transparent insulating film on the mainboard connectors |O |O |O it took hours to take it off with ipa / acetone but now it seems fully functional  :-DMM
next time ill let the "instant" superglue sit for a few hours :)
Offline WackyGerman
« Reply #32 on: February 19, 2017, 12:48:44 pm »
ok , so I wasn t that far away off with my thought of a problem with the dial switch . Hot glue would also work really well and colds down really quick . The main thing is you solved the problem  :-+ :-+
  • Country: hu
« Reply #33 on: February 19, 2017, 01:10:30 pm »
yes i have hot glue gun but it is hard to dispense it precisely.mostly i use epoxy or super glue,usually it hardens within a minute,but the one i used last time(loctite super bond power flex) hardens in about 2 hours (without any caution about that on the package of course)
