Author Topic: Tektronix 760A troubleshooting - Excessively large trace (solved)  (Read 641 times)
Offline SmokescapedTopic starter
Thanks everyone who helped with capacitor advice in the other thread, I successfully got the machine running.
Bad news is the trace is enormous.
Playing with the limit-screw adjustment for focus simply changes the sharpness of the 'trace' without changing its size.
Once again I'm hoping for a helpful push in the right direction to begin troubleshooting this.
Greatly appreciate any feedback. Cheers.
« Last Edit: May 02, 2024, 05:54:38 am by Smokescaped »
Offline BlownUpCapacitor
  • I kinda suck at the art of electronics tbh
Re: Tektronix 760A troubleshooting - Excessively large trace
« Reply #1 on: April 23, 2024, 06:33:15 pm »
reduce the intensity
Hehe, spooked my friends with an exploding electrolytic capacitor the other day 😁.
« Reply #2 on: April 23, 2024, 06:43:58 pm »
On second thought this looks like a HV failure. First measure all voltage rails, make sure they're all fine.
Measure voltage across C34 as well. Should be around +100v.
Measure across R49. Should be 115v.
Measure at pin 2 of J3, the voltage should vary between -15 and +100v depending on the setting of the astigmatism adjustment.
Measure J11. Warning HV here. Report back.
The following users thanked this post: Smokescaped
Re: Tektronix 760A troubleshooting - Excessively large trace (solved)
« Reply #3 on: May 02, 2024, 05:54:24 am »
Thanks mate, reporting back!
It's fixed and the problem was caused by bad resistors in the focus circuit.
R3-R4-R5 were all significantly out of spec. I replaced R1 and R2 while I was there.
