Hello all,
I have a used Fluke 323 clamp meter that is currently not reading AC Voltage correctly. I was wondering if anyone had any tips or thoughts on how to address the issue or what it could be caused by.
Currently when you turn the dial to AC Voltage from the OFF position, the display reads OL, then drops over the span of about 5 seconds to hover between 0-2 V. Testing a standard house outlet from hot to ground results in an OL display on the screen instead of the expected 120V.
It seems as though all other functionality on the meter works fine - Amp clamp, resistance, DC voltage all OK.
Any ideas?
Thanks in advance,
HH
