Author Topic: Repairing an LG WM3997 washer/dryer  (Read 577 times)
ealex, Original, ciradrak, elektryk and 12 Guests are viewing this topic.
Online ciradrakTopic starter
« on: January 15, 2025, 06:09:03 pm »
Over a few days my washing machine spun slower & slower, until the drum would not rotate.  After disassembling the stepper motor everything appeared to be in good condition.  Eventually I measured the incoming voltage lines using a multimeter.  Running the machine's test sequence for the motor showed no voltage using either AC or DC test options.  The wiring all appeared to be fine & ohmed out correctly back to the main circuit board.  Further testing showed that no measure able voltage was being produced by the inverter on the main circuit board.  The board was in cased by rigid plastic & what appears to be clear silicone.  I cut away the plastic housing, which revealed that the board was discolored inside the silicone.  I don’t see the white ash which comes from silicone decomposing from heat, so the discoloration is probably from something else on the board, flux possibly?  At this point I stripped off the silicone from the backside of the board to electrically reach the components.  The silicone was sticky & softer in the discolored areas.
Honestly, I’m not sure what I should be doing to test the board or figure out what is wrong.  None of the capacitors seem obviously exploded.  Any ideas?
Offline BILLPOD
Re: Repairing an LG WM3997 washer/dryer
« Reply #1 on: January 15, 2025, 07:04:06 pm »
Good Morning Ciradrak, Your description makes it sound as if the drum is seized up.  Can you turn the drum by hand?  I've never heard of stepper motors in washing machines, so
maybe you are talking about the main motor that operates the drum.   I've had a washer that the transmission, (which is powered by the motor), seized up.  Your problem may not be electrical, but mechanical.   :popcorn:
« Reply #2 on: January 15, 2025, 07:19:26 pm »
Yes, the drum & motor spin freely.  I took the motor all apart & everything is clean & in good order.  The windings have resistance values which match the specification too.
I think it is a stepper motor?  How could we identify one?
Online coromonadalix
« Reply #3 on: January 15, 2025, 07:26:18 pm »
a stepped motor will rotate in degrees and you feel them,  a brushless one turn freely
« Reply #4 on: January 15, 2025, 07:53:10 pm »
The motor is controlled by three wires & turns freely.  So a brushless one.
Offline fzabkar
« Reply #5 on: January 16, 2025, 10:02:13 pm »
Just for reference ...
https://research.encompass.com/ZEN/sm/WM3997HWA.pdf (service manual)
Direct Drive System
The advanced brushless DC motor directly drives the drum without belt and pulley.
Can you measure the voltages across the two 680uF 250V bulk capacitors before and after the motor is started?
« Last Edit: January 16, 2025, 10:20:49 pm by fzabkar »
Offline tom66
« Reply #6 on: January 16, 2025, 11:03:58 pm »
If the motor was turning slower than expected, it sounds like the machine may be unable to determine the motor's position.  Brushless motors require the controller to know the motor's position accurately to time the sequence of phases correctly.  On most non-drone applications, motor position detection is done by an external transducer like a hall effect sensor or optical encoder.  (Drones and some RC applications detect motor position by back EMF, but this can't work at very low speeds.)
« Reply #7 on: January 18, 2025, 07:06:43 am »
I reassembled the machine with test leads to one of the big 680µF 250V capacitors capacitors.  Powering the machine on took the voltage across the capacitor to 168.8V   Starting the test sequence caused the  motor to shrug & wobble back & forth a bit before going still.  At the height of the wobble the voltage across the capacitor dropped to 162V and then went back up.  Retesting gave the same result, as did hooking the leads to the other capacitor.
The way the motor shrugs when trying to start, it does seem to be failing to figure out the motor’s position.  I do not see anything in the motor that looks like a hall sensor & one does not appear in the wiring diagram for the machine.  The display used to give a read out of rpm for the drum & was capable of spinning at speeds as low as one or two revolutions per second.  The spec says “0-1300 rpm”.  Could it still be using back EMF to know the position of the drum?
I read about brushless DC motors & how simple controllers use six mosfets to control them.  I don’t see anything that looks like an array of six mosfets.  This board is more sophisticated & uses something else, sine wave generators?
I also created a survey of the electrolytic capacitors on the board using a component tester.  I’m not sure if it tells us anything useful as some of the in circuit capacitances are wildly different from the individual components.  Some groups appear to be connected in parallel and give similarly far out readings.  With sealant still on the topside of the board it is difficult to tell where some traces connect.  Some show up as diodes & one registers as ’unknown’.  Of the ones that give reasonable readings several are borderline on a basic ESR chart, but one CE181 is way out.  So that could be a problem?  That capacitor is also in an area of the board which shows the most discoloration under the silicone.
Offline ifonlyeverything
« Reply #8 on: January 18, 2025, 02:19:42 pm »
Maybe try to identify some of the ICs, find the voltage supply pin via data sheet lookup, and then measure their supply voltage? Confirming stable supply voltages is always a good starting point.
If you can't identify hall encoders, rotary encoders, etc. then I would also guess that it is using back EMF. It might be worth investigating the integrity of the wires/connectors between the PCB and the motor. Washing machines definitely see a lot of vibration.
« Last Edit: January 18, 2025, 02:23:35 pm by ifonlyeverything »
Offline Poroit
« Reply #9 on: Yesterday at 03:52:18 am »
115 x 1.414 =162.
Your 680uF caps are OK.
The electrical circuit does not show any standalone sensors that control the motor so I assume it must be on the Control PCB.
https://electronics.stackexchange.com/questions/365796/how-do-single-phase-bldc-motors-start-in-proper-direction
Does the machine throw up an error in LOAD TEST MODE?
« Reply #10 on: Today at 03:14:15 am »
I'm working on understanding & carrying out the other instructions.
Putting the machine into LOAD TEST MODE shows three rotating codes on screen.
15:47
U:11
d:04
I don't know what that means, but it does not seem to be an error.
« Reply #11 on: Today at 04:10:49 am »
Here are the coils & magnets inside the motor from when it was disassembled.   I count 12 magnets & 36 coils.
Online Original
  • Country: gr
« Reply #12 on: Today at 04:46:20 am »
if the drum does rotate a few degrees (not full turns) on its own and then stop, then your problem is here:
« Reply #13 on: Today at 04:55:40 am »
I got really excited for a few minutes there, that maybe the problem was about to be solved, but as you can see in the photo of the windings, this machine does not have a rotor position sensor switch.   :'(
Online Original
  • Country: gr
« Reply #14 on: Today at 05:06:15 am »
the sensor is on the back take off the motor assembly!
« Last Edit: Today at 05:09:33 am by Original »
