I suggest checking all the input protection like the PTC, MOVs, fusible resistor, etc. The PTC should be around 1K ohm, the MOV's should be open circuit and fusible resistor around 1K ohm.
Also, if your 289 had battery leakage, it would be a good idea to clean the entire PCB with 99% IPA.
