They are 100% repairable. Easy $50 to $150 I tell you, if you doing these repairs on regular, think $500 and up a day, free money.
This particular cap looks bloated to my eye. Plus you saying rectifier fault, that means voltage isn't as straight as it should be. I say pull all 3 caps, check them, replace as needed. But in your case, since you don't have LCR meter, you just replace all 3 caps. Caps can have larger capacitance, just make sure voltage is at least that what those caps are and they fit in.
Where to get caps? Here I have a store, I can run to it and buy caps. In larger city I would have pickup points for what is equivalent to digikey and farnell. Plus I could pick them in equivalent of amazon and have them delivered to pickup point for free. Your options depend on what is available in ausie land. Be careful with ali, sometimes large caps are fake, you open them up and inside is a small cap.
